<< Click to Display Table of Contents >> Toolbar |
A Screen's Toolbar contains options that allow users to execute certain tasks quickly without using menus, such as adding a Command Button. The next table contains the available options on a Screen's toolbar.
Available options on the toolbar of a Screen
Option |
Description |
Select |
Enables a selection mode |
Pan |
Enables using the pan feature on a Screen. NOTE: At run time, this option is available only if a Screen's ScreenAlignment property is defined as paCenter |
Area Zoom |
Allows applying a zoom to a specific area of a Screen. To do so, left-click the initial point and drag the mouse to the final point. NOTE: At run time, this option is available using the shortcut key CTRL + SHIFT + Left mouse button, but only if a Screen's ScreenAlignment property is configured as paCenter |
Fit |
Toggles between resizing the Screen to fit in the visible area and restoring the previous zoom level and scroll bar position (CTRL + 5 or CTRL + CLEAR) |
Rotate |
Enables a rotation mode |
Tab Order |
Shows an identification for a browsing order among objects |
Edit Connection Points |
Allows editing connection points among objects. This option is only enabled in XControl objects |
Brings an object to the front inside a group (ALT + HOME) |
Send to Back |
Sends an object to the back inside a group (ALT + END) |
Bring Forward |
Brings an object forward inside a group (ALT + PAGE UP) |
Send Backward |
Sends an object backward inside a group (ALT + PAGE DOWN) |
Zoom |
Allows editing the level of zoom of a Screen |
Layers |
Allows editing the layers of objects on a Screen |
E3Alarm |
Inserts an E3Alarm-type object |
E3Browser |
Inserts an E3Browser-type object |
E3Chart |
Inserts an E3Chart-type object |
Playback |
Inserts an E3Playback-type object |
Line |
Inserts a Line-type object |
Connector |
Inserts a Connector-type object |
Rectangle |
Inserts a Rectangle-type object |
Rounded Rectangle |
Inserts a Rounded Rectangle-type object |
Ellipse |
Inserts an Ellipse-type object |
Arc |
Inserts an Arc-type object |
Freehand |
Inserts a Freehand-type object |
Polygon |
Inserts a Polygon-type object |
Curved Polygon |
Inserts a Curved Polygon-type object |
Text |
Inserts a Text-type object |
Display |
Inserts a Display-type object |
SetPoint |
Inserts a SetPoint-type object |
Picture |
Inserts a Picture-type object |
Scale |
Inserts a Scale-type object |
Group |
Groups a selection of objects |
Ungroup |
Ungroups a selection of objects |
Linear Slider |
Inserts a tool for linear sliding |
Rotation Slider |
Inserts a tool for rotation sliding |
Check Box |
Inserts a Check Box-type object |
Option Button |
Inserts an Option Button-type object |
Combo Box |
Inserts a Combo Box-type object |
Command Button |
Inserts a Command Button-type object |
Label |
Inserts a Label-type object |
List Box |
Inserts a List Box-type object |
Scroll Bar |
Inserts a Scroll Bar-type object |
Spin Button |
Inserts a SpinButton-type object |
Text Box |
Inserts a TextBox-type object |
Toggle Button |
Inserts a Toggle Button-type object |
Aligns two or more objects to each other, using as reference the left coordinate of the last selected object |
Align Right |
Aligns two or more objects to each other, using as reference the right coordinate of the last selected object |
Align Top |
Aligns two or more objects to each other, using as reference the top coordinate of the last selected object |
Align Bottom |
Aligns two or more objects to each other, using as reference the bottom coordinate of the last selected object |
Align Horizontal Center |
Aligns two or more objects horizontally by the center to each other, using as reference the last selected object |
Align Vertical Center |
Aligns two or more objects vertically by the center to each other, using as reference the last selected object |
Same Width |
Applies the width of the last selected object to all other selected objects |
Same Height |
Applies the height of the last selected object to all other selected objects |
Same Size |
Applies the width and height of the last selected object to all other selected objects |
Center Horizontally |
Centers an object on a Screen, according to its horizontal coordinates |
Center Vertically |
Centers an object on a Screen, according to its vertical coordinates |
Space Across |
Applies the same horizontal distance to three or more objects to each other |
Space Down |
Applies the same vertical distance to three or more objects to each other |
Applies a horizontal reflection effect to the selected objects |
Applies a vertical reflection effect to the selected objects |
Grid |
Shows or hides the grid |
Edit Grid |
Allows editing grid properties |
Allows selecting a background color for a Screen or for a Screen object from a list of pre-defined colors or create a new custom color |
Foreground Color |
Allows selecting a foreground color for a Screen or for a Screen object from a list of pre-defined colors or create a new custom color |
Border Color |
Allows selecting a border color for a Screen object from a list of pre-defined colors or create a new custom color |
Border Style |
Allows selecting the type of border displayed by a Screen object from a list of pre-defined styles. Possible values for this option are Normal, Dash, Dot, DashDot, DashDotDot, or No Border |
Border Thickness |
Allows selecting a thickness for the border line of a Screen object from a list of pre-defined thicknesses between 0 (zero) and 2.5 millimeters |
Allows selecting a fill type displayed by a Screen or by a Screen object, that is, how a match is performed between background and foreground colors of an object |
Applies a shadow to an object |
Move Shadow Up |
Moves an object's shadow up |
Move Shadow Down |
Moves an object's shadow down |
Move Shadow Left |
Moves an object's shadow to the left |
Move Shadow Right |
Moves an object's shadow to the right |
Shadow Color |
Selects an object's shadow color |
Font |
Determines a text's font |
Font Size |
Determines a size for a text's font |
Font Color |
Determines a color for a text's font |
Bold |
Formats a text in bold |
Italic |
Formats a text in italic |
Underlined |
Formats a text in underline |
Align Left |
Aligns a text to the left margin |
Align to Center |
Aligns a text to the center |
Align Right |
Aligns a text to the right margin |
Refresh Domain and Run Viewer from Current Screen |
Refreshes the Domain, executes Elipse E3 Viewer, and displays the current Screen. This option is only available if a Domain is executing, that is, after using the Runs or Stops Domain |
