<< Click to Display Table of Contents >> E3Alarm |
Possible Causes
To check an E3Alarm configuration, verify whether the Server name is correctly configured. Another possibility is the existence of more than one Alarm Server in a Domain, which can cause trouble. Another error situation would be a Filter configured for a non-existent Alarm Area.
Solution
Make sure that there is only one Alarm Server in this Domain, and that all Alarms are correctly configured. Also check if this configured Area exists.
First, group these Areas into a main Area. Then, use names with the same characters at the beginning, such as ALM1MEC, ALM1ELE, ALM2MEC, or ALM2ELE.
Enable the Acknowledge Alarm option, located in the properties of the desired column in an E3Alarm, on the Columns tab.
