Visibility of Pens
Visibility of Pens
1.To enable or disable the visibility of a Pen, add a Check Box Check Box on the ChartScreen.
2.On this Check Box, create a script on its Change event and select the Visible property of Level1 Pen on AppBrowser.
Pen's Visible property
3.Click Paste and type the expression " = Value" at the end of the line, according to the next code.
Screen.Item("E3Chart1").Pens.Item("Level1").Visible = Value
4.Configure the initial value, the Value property, of the Check Box to True.
5.Repeat the previous steps for the Level2 Pen.
Check Box for Pen visibility
NOTE
For Pens to keep displaying on a chart's legend, change the Legend's ShowAllPens property to True. This property is only available via script.
