Enable or Disable Log Sections
Users can define which log Sections are enabled. Sections can be subdivided into modules, so users can enable each module separately. Each module contains a configuration item with a question Enable log section/module?.
If items are not modified, the system automatically assumes that logs are not created. If items are modified, a No answer disables log creation, except for IOData Section, exemplified in details on Notes, and an Yes answer enables Section log. Modifying a Section value implies in changing all Module values inside that Section.
NOTES
IOData Section is an exception to this case. Its corresponding item is Disable IOData section. Not changing this item is the same as enabling this Section. Changing it by answering No to question Enable log section/module? disables this Section
Changing these variables can be performed while E3 is executing, and it is applied up to 30 seconds after execution
Available log Sections are described on the next table.
Log Sections and their respective modules
Section
Description
DB
Shows errors on database or data discard operations, as well as results of operations executed on acquisition and execution threads
EdbSync
Log with informative messages about the process of importing and syncing external electrical models
ImportExport
Log generated by E3 Studio on data importing or exporting processes
IOData
Shows data read and written by E3Run
Playback
Log generated by E3Playback
RECRaw
Detailed log of REC communications. Available modules on this section are Client: Records request packages and Server: Records response packages
Storage
Allows tracking Storage operations. Available modules on this Section are Dropped: Lists all values discarded by a Storage, Input: Lists all variations of Tag values linked to a Storage, and Stored: Displays all values sent by a Storage to a Database
Sync
Allows monitoring information synced between E3 Server and E3Run, and among E3 Servers in Hot-Standby mode. Available modules on this section are Alarm: Shows alarm messages generated by E3Run, which are passed to an alarm summary kept by E3 Server and Vars: Shows changes made on E3 Server's persistent Tags database
Undo
Records system activities of E3 Studio's Undo menu
There are special log sections that record operations executed on a specific thread, as well as their duration. Only operations that last more than a certain time, whose default value is 100 ms, are logged. These logs allow checking when E3 processing becomes slow, almost stopped. Available special log sessions are described next.
Full: Main log gathering general information about E3 Server, E3Run, E3 Studio, and E3 Viewer execution. Available modules are described on the next table.
Available modules for Full logs
Module
Description
AccessChecker
Thread responsible for checking Domain's permissions or access in E3 Server (E3Run)
AlarmCallbackManager
Thread responsible for receiving alarm events from Remote Domains (E3Run)
AlarmQueue
Threads responsible for sending alarm events
AlarmServer
E3Run's thread responsible for asynchronously sending Alarm events
DBCallbackManager
Thread responsible for receiving and storing in cache the statistics sent by the E3DBEngine process
DefragDlg
Thread responsible for the defragmentation of project and library files (Studio)
DomainManager
E3 Server Domain's state manager thread, that is, opens or closes the active Domain, updating a Domain based on changes on .dom files
E3Admin
E3 Admin's main thread
E3Runtime
E3Run's main thread, allows identifying locks or slowdowns during E3's execution
E3Server
E3 Server's main thread
EdbSync
Thread responsible for the process of importing and syncing external electrical models
EventQueue
E3 Server's threads responsible for sending asynchronous Link events
IOManager
E3Run's thread responsible for receiving data generated by IOServers
LicenseManager
E3 Server's license check thread
LinePrinter
Thread responsible for sending asynchronous data to Line Printers (E3Run)
Link2Stub
E3Run's thread responsible for asynchronously sending Link events
OpcAsyncCreateServer
OPC client's threads responsible for isolating the connection and access to an OPC server
OpcCallback
E3Run's or E3 Studio's thread responsible for asynchronously receiving events from OPC clients
OpcClient
Thread where the OPC client is executed
OpcClientHost
Main OPC client's thread
OPCGroup
Thread responsible for sending notifications from E3's OPC server (E3Run)
OpcQueue
Thread responsible for sending OPC client's notifications asynchronously
PowerCADWarmUp
Thread used to perform a PowerCAD pre-loading when opening Elipse Power Studio
PowerHubReceive
Thread responsible for receiving notifications from electrical studies (E3Run)
PowerHubReceive2
Thread responsible for receiving notifications from electrical studies in EDB format (E3Run)
PowerHubSend
Thread responsible for sending updates to electrical studies (E3Run)
PowerHubSend2
Thread responsible for sending updates to electrical studies in EDB format (E3Run)
RECAppartment
Thread used to manage the transmission of REC packets during a connection
RECChannel
Thread used to manage the transmission of data via network in REC connections
RemoteDomain
E3 Server's threads responsible for managing client connections from Remote Domains
RemoteDomainsManager
Thread where management of RemoteDomain sets occurs
SafeServerSession
Thread responsible for access or maintenance of retentive data from a Domain (E3Run)
ServerControl
E3 Server's threads responsible for managing a local or remote Domain server
ServerControlCallback
Thread responsible for sending notifications to E3 Admin (E3 Server)
ServerControlMonitor
E3 Server's thread responsible for automatically starting E3 Admin for logged in users
ServerLinkManager
E3 Server's thread implementing Link management
ServerSubscriptionManager
Thread responsible for managing alarm signature connections
StandbyAlgorithm
E3 Server's thread implementing Hot-Standby algorithm decisions
Studio
E3 Studio's main, or interface, thread
ThreadPool
Reusable E3DBEngine process' thread responsible for executing queries
UaCallback
Thread responsible for receiving notifications from OPC UA clients (UaDriver)
UaClient
OPC UA client's main thread
UaQueue
Thread responsible for sending notifications from OPC UA clients (UaDriver)
VideoRecorder
Thread used to manage video recording in an E3Playback
Viewer
E3 Viewer's main, or interface, thread, allows diagnosing Screen opening time, script execution time, etc.
FullDB: Records operations of E3 database access' threads, generated by E3Run and E3 Server. Available modules are described on the next table.
Available modules for FullDB logs
Module
Description
DBAcquisition
Thread that sends application-generated data to queue files, the .e3i files
DBCallback
Thread that sends statistics about connections and operations finished or failed for the parent process
DBEngineHost
E3DBEngine process' main thread
DBExec
Thread that removes operations from queue files, the .e3o files, and executes commands on a database
OCIThread
OCI's (Oracle Call Interface) thread
WatchDog
E3DBEngine process' thread responsible for terminating this process if a lengthy operation is locked
FullIO: Records activities on IOServer's threads. Available modules are described on the next table.
Available modules for FullIO logs
Module
Description
CallBack
Thread for sending data collected by a Driver to E3Run
Driver
Thread executing a Driver
IOServer
IOServer's main thread, which receives Driver configuration and requests sent by E3Run
UaClientHost
E3UaClient process' main thread
WatchDog
IOServer's thread responsible for terminating this process if any lengthy operation is locked
FullPower: Records detailed information on PowerEngine2 threads, that is, electrical model files in EDB format. This log records, for example, information about performance diagnosis, in addition to detailed results of several operations. Available modules are described on the next table.
Available modules for FullPower logs
Module
Description
DistLoadModel
Module responsible for calculations on Distribution Load Modeling Electrical Study
External Reader
Module responsible for calculations on External Reader Electrical Study
LoadShedding
Module responsible for calculations on Load Shedding Electrical Study
PowerEngine
Elipse Power's main module, responsible for handling Elipse Power requests
PowerFlow
Module responsible for calculations on Power Flow Electrical Study
SelfHealing
Module responsible for calculations on Self-Healing Electrical Study
Send
Module responsible for sending results generated by several Electrical Studies to E3
StateEstimator
Module responsible for calculations on State Estimator Electrical Study
TopologyProcessor
Module responsible for calculations on Topology Processor Electrical Study
Workspace
Module responsible for centralizing values of Measurements used by Electrical Studies
PowerEngine: Records general information on PowerEngine2 threads, that is, electrical model files in EDB format. Available modules are described on the next table.
Available modules for PowerEngine logs
Module
Description
DistLoadModel
Thread with information about Distribution Load Modeling Electrical Study
ExternalReader
Thread with information about External Reader Electrical Study
Input
Thread with input information for Measurements and Measurement Sources
LoadShed
Thread with information about Load Shedding Electrical Study
Output
Thread with output information for Measurements and Measurement Sources
PowerEngine
Thread with global information about PowerEngine
PowerFlow
Thread with information about Power Flow Electrical Study
SelfHealing
Thread with information about Self-Healing Electrical Study
StateEstimator
Thread with information about State Estimator Electrical Study
TopologyProcessor
Thread with information about Topology Processor Electrical Study
Workspace
Thread with information about Measurement values used by Electrical Studies
NOTE
Module configuration only has precedence over Section configuration.
