Domain Information |
This section contains information about the methods and properties of a Domain Information (DomainNode) object. This object does not contain events associated to it.
NOTES |
•This object and all its child objects contain the general properties Count, Name, and Parent, and also the general method Item. Users can also use the For Each statement in scripts to enumerate its child objects. •Using brackets when referencing this object in scripts, such as "[?Server].Domain", is mandatory. |
