Count |
Returns the number of child objects, or items, an object contains. This property works together with the Item method. If the object does not have any child objects, the returned value is 0 (zero). This is a read-only property. Example:
Sub Screen1_Click()
' Searches all Screen objects and sets
' the ForegroundColor property to red
Dim obj
For i = 1 To Count
Set obj = Item(i) ' Gets a child object
obj.ForegroundColor = RGB(255, 0, 0)
Next
