Server Information |
This section contains information about the properties of a Server Information (ServerNode) object. This object does not contain events nor methods associated to it..
NOTES |
•This object and all its child objects contain the general properties Count, Name, and Parent, and also the general method Item. Users can also use the For Each statement in scripts to enumerate its child objects. •Using brackets when referencing this object in scripts, such as "[?Server]", is mandatory. |
