BlinkOnValue |
This property specifies an alternative value the property assumes periodically when source's expression returns True and the BlinkOn property is set to True. Example:
Sub BlinkOnValue_Click()
On Error Resume Next
Dim Value
If Application.ShowPickColor_
(Value, ForegroundColor, 400, 300) Then
Dim Bind
Set Bind = Screen.Item("Rectangle1").Links._
Item("ForegroundColor")
If Bind Is Nothing Then
MsgBox "Rectangle1 has no link."
Else
MsgBox "Rectangle1 is linked to " & Bind.Source & "'"
MsgBox "Changing BlinkOnValue from " &_
Bind.BlinkOnValue & " to " & Value
Bind.BlinkOnValue = Value
End If
ForegroundColor = Value
End If
