BlinkOn |
When this property is set to True, the connected property alternates periodically between values of OnValue and BlinkOnValue properties, in case the source returns True. Example:
Sub BlinkOn_Change()
On Error Resume Next
Dim Bind
Set Bind = Screen.Item("Rectangle1")._
Links.Item("ForegroundColor")
If Bind Is Nothing Then
MsgBox "Rectangle1 has no link."
Else
MsgBox "Rectangle1 is linked to " & Bind.Source & "'"
MsgBox "Changing BlinkOn from " &_
Bind.BlinkOn & " to "_ & Value
Bind.BlinkOn = Value
End If
