E3Alarm |
Viewing Alarms in real-time can be performed using an E3Alarm object.
1.Place an E3Alarm object on AlarmScreen.
E3Alarm on AlarmScreen
2.In E3Alarm's Properties Window, on Connections tab, inform an Alarm Server's name on Alarm Server column of the default Connection.
Connections tab
3.On Columns tab, select the DateTime, Operator, Message, Acked, and Value fields.
4.On Colors tab, configure it as needed.
5.Execute this application and check its functionality.
