Online Server
Online Server
1.Go to www.elipsemobile.com and, if not yet available, create an account by clicking Try It Free.
2.Fill in your data in the About you group and, in the Your application field, type a name for this application. This name is used to complete the access URL.
Creating an account and an application
3.An e-mail is then sent with instructions to activate this account. Click the link sent with that e-mail to go to Elipse Mobile's web page.
4.Click Go to administration panel.
5.Select the application previously created and type the user and password used to create this account.
User and password of the application
6.Click the main menu Main menu on the top left corner and select the Connections item.
Connections item
Connections item
7.Add a new Connection and select the E3\Power item.
E3\Power Connection
E3\Power Connection
8.Type a name and a password for this connection and save this configuration.
9.Click Installer to download Elipse CloudLink installer.
10.Install this software and click Download config.clf. Open this file and inform the connection name and password created previously.
Elipse CloudLink configuration
11.Click Settings to define whether the E3 application is executing locally or on a network machine. In the Permissions item, select the Enable Write option to allow writing permissions.
Settings window
Settings window
12.After configured, Elipse CloudLink is executed.
Application executing
13.Click Go to home page Página inicial to return to the initial page.
14.Click Edit Editar.
15.Add a new control of type Setpoint.
16.In this control, configure the amount of red from Tank1 when accessing Internal Tag Red on Folder Tank1.
Internal Tag
Internal Tag
17.Click Tag Tag to access the Internal Tag Red, according to the next figure.
Selecting a Tag in the application
NOTE
To access Tags from an E3 application, the Domain must be active.
18.Configure all other options as needed and click Save.
19.Click Run and click the Setpoint object to change its value. Compare with the value of the Internal Tag in the E3 application.
