Alarm Server |
1.Open Alarm Server's Properties Window and, on the Configuration tab, enable the Store alarms on a database option.
Configuration tab
2.In the Database Server option, select the Database item.
3.Enable the Discard data from the main table option.
•Keep data from the last 3 months
•Check must occur at every 1 month
4.Click Fields and select the InTime field and any other field needed.
5.Finally, click Create table. A successful message must be displayed, as shown on the next figure.
Success message
