Users |
•Fixed a problem when loading the position of internal splitters of windows. This bug occurs since v4.8.98.
•The position of splitters of Users and Groups tabs of the User Permissions window now are correctly saved. This bug occurs since v4.8.98.
•E3 Studio and E3 Viewer sessions periodically check whether the logged in user is valid. This bug occurs since v3.2.1.
•Now a logged-in user in E3 Viewer or in E3 Studio is not affected when the password is changed on another session. This bug occurs since v1.20.366.
•The ChangePassword method now correctly checks the informed password, by considering the option to ignore case. This bug occurs since v3.0.320.
•When trying to save changes on the user database, these changes are applied to the most updated version of the user database, preserving previous changes and logging an error if there is any conflict that cannot be solved automatically. This bug occurs since v3.0.355.
•Fixed an error that discarded a password change if a login occurred immediately after. This bug occurs since v1.20.319.
•The window to edit users in E3 Studio now is closed when a Domain is unloaded. This bug occurs since v3.0.420.
