GetValue
GetValue
GetValue(TagName)
This method searches for an object's value specified in the TagName parameter. If TagName points to a property, this method returns that property's value. However, if TagName parameter specifies an object, this method returns the value of that object's Value property. Example:
Sub Button1_Click()
  ' When clicking this button
  ' retrieves a Tag value
  ' executed on a Data Server
  X = Application.GetValue("DataServer1.InternalTag1")
