PicturePosition
PicturePosition
Enum Indicates the position of the selected picture on Screen's PictureFile property. This property is only valid if the FillStyle property is set to 12 - Picture. Valid options for this property are described on the next table.
Available options for PicturePosition
Option
Description
0 - Center
Picture with original size, centered on Screen (default)
1 - Tile
Picture with original size, repeated as many times as needed to fill a Screen
2 - Stretch
Picture resized to fill a Screen
3 - TopLeft
Picture with original size, on the left upper corner of a Screen
4 - BottomLeft
Picture with original size, on the left lower corner of a Screen
5 - BottomRight
Picture with original size, on the right lower corner of a Screen
6 - TopRight
Picture with original size, on the right upper corner of a Screen
