FillStyle
FillStyle
Enum This property specifies a fill style for Screens. The next table contains valid values for this property.
Available options for FillStyle
Option
Description
0 - Solid
Fill style is solid (default)
2 - Horizontal
Fill style contains horizontal stripes
3 - Vertical
Fill style contains vertical stripes
4 - Downward
Fill style contains stripes from down left to right in a 45-degree angle
5 - Upward
Fill style contains stripes from up left to right in a 45-degree angle
6 - Cross
Fill style contains horizontal and vertical stripes
7 - DiagonalCross
Fill style contains diagonal stripes up and down from left to right in a 45-degree angle
8 - Gradient
Fill style contains a gradient using ForegroundColor as well as BackgroundColor. This effect is defined by the GradientStyle property
11 - Background
Fills the Screen with the color defined in the BackgroundColor property
12 - Picture
Fills the Screen with the picture selected in the PictureFile property
