GradientStyle
GradientStyle
Enum This property specifies a gradient fill style for a Screen. This property is only used when the FillStyle property is set to 8 (eight, Gradient). Gradients consider a color change as starting from the color configured in the ForegroundColor property and moving towards the color configured in the BackgroundColor property.
Available options for the GradientStyle property
Option
Description
0 - LeftToRight
Vertical gradient, from left to right (default)
1 - RightToLeft
Vertical gradient, from right to left
2 - VertToCenter
Vertical gradient, from border to center
3 - VertFromCenter
Vertical gradient, from center to border
4 - TopDown
Horizontal gradient, from top to bottom
5 - BottomUp
Horizontal gradient, from bottom to top
6 - HorzToCenter
Horizontal gradient, from border to center
7 - HorzFromCenter
Horizontal gradient, from center to border
8 - DiagDownRight
Diagonal gradient to the bottom, with foreground color on the right
9 - DiagUpLeft
Diagonal gradient to the top, with foreground color on the left
10 - DiagUpToCenter
Diagonal gradient to the top, from border to center
11 - DiagUpFromCenter
Diagonal gradient to the top, from center to border
12 - DiagDownLeft
Diagonal gradient to the bottom, with foreground color on the left
13 - DiagUpRight
Diagonal gradient to the top, with foreground color on the right
14 - DiagDownToCenter
Diagonal gradient to the bottom, from border to center
15 - DiagDownFromCenter
Diagonal gradient to the bottom, from center to border
16 - SpotBottomRight
Gradient with foreground color, from right lower corner
17 - SpotBottomLeft
Gradient with foreground color, from left lower corner
18 - SpotTopLeft
Gradient with foreground color, from left upper corner
19 - SpotTopRight
Gradient with foreground color, from right upper corner
20 - SpotFromCenter
Gradient with background color, from center to border
21 - SpotToCenter
Gradient with background color, from border to center
