Open Modal Screen
Open Modal Screen
Opens a Modal Screen, that is, a Screen that does not allow user interaction with other Screens while it is active.
Settings for the Open Modal Screen Pick
Available options for Open Modal Screen Pick
Option
Description
Open Screen
Selects the Screen to open
Title
Defines the window title. This text is concatenated to the Screen's name
Initial zoom
Defines Screen's zoom, when displayed
Parameter
Indicates a parameter to pass when calling the Screen
Enable scrollbar
Allows using scroll bars on the Screen
Specify screen position
Determines the frame's position, in pixels, on the Screen, starting at Screen's upper left side
Specify screen size
Determines Screen's width and height, in pixels or Himetric
Window Style
Allows configuring the style of the window to display, by defining title and the availability of borders and the close, maximize and minimize buttons, among other settings (check the Window Style Dialog Box topic)
