InsertColumn
InsertColumn
InsertColumn(Col, Index)
Inserts a new column on a Legend. This method contains the following parameters:
Col: Identifies a column to insert (please check the Available options to identify a Legend column table at the beginning of topic Legend Methods)
Index: Determines the position to insert this column
Example:
Sub CommandButton1_Click()
  'Displays the Pen's name
  Screen.Item("E3Chart1").Legend.InsertColumn 0, 0
  'Displays the Pen's color
  Screen.Item("E3Chart1").Legend.InsertColumn "Color", 0
