Methods
Methods
On a Legend, several columns can be selected. Each column displays a type of information and contains a corresponding name and value. The following table displays all possible columns on a Legend.
Available options to identify a Legend column
Option
Value
Name
Description
AverageY
10
AverageY
Shows a Pen's average value in this interval
BeginX
13
XBegin
Shows a cursor's initial position
BeginY
17
YBegin
Shows the interpolated point where the initial cursor meets a Pen
DiffX
15
DiffX
Shows the difference between initial and final cursors
DiffY
16
DiffY
Shows the difference between initial and final interpolated points on the Y Axis
EndX
14
XEnd
Shows a cursor's final position
EndY
18
YEnd
Shows the interpolated point where the final cursor meets a Pen
MaximumY
12
MaxY
Shows a Pen's maximum value in this interval
MinimumY
11
MinY
Shows a Pen's minimum value in this interval
Pen color
6
Color
Shows a Pen's color
Pen description
5
Description
Shows a Pen's DocString property
Pen name
0
Name
Shows a Pen's name
ScaleYMax
20
ScaleYMax
Shows the maximum value of a vertical scale
ScaleYMin
21
ScaleYMin
Shows the minimum value of a vertical scale
Status
7
Status
Shows a Pen's status
Unit
19
EU
Shows a Pen's engineering unit
X tag name
1
TagX
Shows a Tag's name linked to the X Axis
X tag value
3
TagXValue
Shows a search value on X Axis
XScale
8
ScaleX
Shows the X Axis' name linked to a Pen
Y tag name
2
TagY
Shows Tag's name linked to the Y Axis
Y tag value
4
TagYValue
Shows a search value on Y Axis
YScale
9
ScaleY
Shows the Y Axis' name linked to a Pen
The available methods on this section are the following:
ChangeColumnPos
InsertColumn
Item
RemoveColumn
