Bit00 to Bit31
Bit00 to Bit31
Boolean Bit properties Bit00 to Bit31 all represent the 32 bits in I/O Tag's Value property, where Bit00 is the least significant bit and Bit31 is the most significant bit. By modifying each one of these bits implies in modifying Tag's Value property, and vice versa, but this only happens when the UseBitFields property is set to True. Default value of these properties is False.
