SetFrameOptions
SetFrameOptions
SetFrameOptions(Title, [Flags])
Used to configure Frame's title on a window and that window's style. The Title parameter is a String that contains window's title. This text is displayed if Screen's Caption property is empty.
The Flags parameter specifies window's style. If this parameter is omitted, its default value is -1 (minus one). This value is used to keep window's previous configuration. When this value is not -1 (minus one), users can change window's style by specifying a sum of values of all combinations described on the next table.
Possible combinations for the Flags parameter
Value
Description
1
Enables a title bar on this window
2
Enables a Close button on this window
4
Enables a Minimize button on this window
8
Enables a Maximize button on this window
16
Enables a border on this window
32
Specifies that this window can be resized (to do so, this window must have a border)
64
Specifies that this window can be moved
256
Specifies that this window stays on top of a Screen
512
Specifies that this window is configured in a Tool Bar style
1024
Disables object buttons
2048
Centers this window
Example:
Sub Screen_OnPreShow()
  Frame.SetFrameOptions("Alarm Screen", 114)
In the previous example, the value 114 (2 + 16 + 32 + 64) indicates that this window contains a Close button enabled (2), a border (16), can be resized (32), and can be moved (64). This window's title is "Alarm Screen".
In the Open Screen and Open Modal Screen Picks, users can also configure a window style during edition, by using the Window Style dialog box. For more information, please check topic Picks.
NOTE
The SetFrameOptions method must be used after calling the SetDisableTaskSwitching method, if users want to change window's title or style.
