SummaryGroup
SummaryGroup
Text This property is only valid when the SummaryType property is equal to 3 - SubTotal. This property indicates the name of a GroupHeader Section used to control subtotals, that is, at every change in GroupHeader's value, the sum is restarted.
NOTE
When this property is used, the CanShrink and CanGrow properties remain disabled.
