CanShrink
CanShrink
Boolean Determines whether to apply a shrinking effect to a text in a SetPoint object. If this object's width or height decrease, the text accompanies this variation. If this property is set to True, text accompanies object's height and width variations. Otherwise, this object remains with its initial settings. Default value of this property is True.
