SummaryFunc
SummaryFunc
Enum Determines the type of function used for processing field values specified in the DataField property, as described on the next table. This property is only valid when the SummaryType property is different from 0 (zero).
Available options for the SummaryFunc property
Option
Description
0 - ddSFSum
Calculates the sum of all values inside the range of specified total values (default for group, page, or Report)
1 - ddSFAvg
Calculates the average of all values inside the range of specified total values (group, page, or Report)
2 - ddSFCount
Counts the number of values inside the range of specified total values (group, page, or Report)
3 - ddSFMin
Displays the lowest value (minimum value) inside the range of specified total values (group, page, or Report)
4 - ddSFMax
Displays the highest values (maximum value) inside the range of specified total values (group, page, or Report)
5 - ddSFVar
Calculates the variance of values inside the range of specified total values (group, page, or Report)
6 - ddSFVarP
Calculates the population variance of values inside the range of specified total values (group, page, or Report)
7 - ddSFStdDev
Calculates the standard deviation of values inside the range of specified total values (group, page, or Report)
8 - ddSFStdDevP
Calculates the population standard deviation of values inside the range of specified total values (group, page, or Report)
9 - ddSFDSum
Calculates the sum of all distinct values inside the range of specified total values (group, page, or Report)
10 - ddSFDAvg
Calculates the average based on distinct values inside the range of specified total values (group, page, or Report)
11 - ddSFDCount
Counts the number of distinct values inside the range of specified total values (group, page, or Report)
12 - ddSFDVar
Calculates the variance of distinct values inside the range of specified total values (group, page, or Report)
13 - ddSFDVarP
Calculates the population variance of distinct values inside the range of specified total values (group, page, or Report)
14 - ddSFDStdDev
Calculates the standard deviation of distinct values inside the range of specified total values (group, page, or Report)
15 - ddSFDStdDevP
Calculates the population standard deviation of distinct values inside the range of specified total values (group, page, or Report)
