HorizontalFillStyle
HorizontalFillStyle
Enum Defines a horizontal fill for this object. This property works along with the HorizontalPercentFill, property, which informs a percentage of this object that must be filled. These two properties allow simulating a level fill in an object, such as a tank level, for example.
Available options for the HorizontalFillStyle property
Option
Description
0 - FillLeftToRight
Fill percentage is from left to right (default)
1 - FillRightToLeft
Fill percentage is from right to left
2 - FillCenterToEdgesH
Fill percentage is from center to border
