OnCommErrorEx
OnCommErrorEx
OnCommErrorEx(ErrorInfo)
Occurs right after the execution of an OnCommError event.
ErrorInfo parameter information
Name
Description
ErrorInfo.EvtType
Indicates the type of operation that caused this error:
0: Tag reading
1: Tag writing
2: Block reading
3: Block writing
ErrorInfo.Size
Size of the Block that caused this error (if it is a Tag, Size is equal to 1)
ErrorInfo.Element
Index of the Block Element that caused this error
ErrorInfo.Nx
Nx or Bx parameters (x = 1, 2, 3, 4) of the operation that caused this error
ErrorInfo.ParamDevice
ParamDevice parameter (String) of the operation that caused this error
ErrorInfo.ParamItem
ParamItem parameter (String) of the operation that caused this error
