OnCommError
OnCommError
OnCommError(EvtType, Size, Element, N1, N2, N3, N4)
Occurs when an I/O Driver detects any writing or reading error. Use an OnCommError event to check when a writing or reading failure occurred in the I/O Driver. Event variables receive information about this error. With these values, users can track back Tags with I/O problems.
OnCommError event variables
Name
Description
EvtType
Informs which type of operation a Driver was performing when this error occurred, according to the following options:
0: Single Element reading error (Size = 1). Param1 is N1, Param2 is N2, Param3 is N3, and Param4 is N4
1: Single Element writing error (Size = 1). Param1 is N1, Param2 is N2, Param3 is N3, and Param4 is N4
2: Block reading error (I/O Block). Size is determined by the number of Block Elements. Param1 is N1, Param2 is N2, Param3 is N3, and Param4 is N4
3: Block writing error (I/O Block). Size is determined by the number of Block Elements. Param1 is N1, Param2 is N2, Param3 is N3, and Param4 is N4
Size
Number of values being read or written
Element
Index of the Element being read or written inside a Block
N1
First parameter of a reading or writing operation that generated this error
N2
Second parameter of a reading or writing operation that generated this error
N3
Third parameter of a reading or writing operation that generated this error
N4
Fourth parameter of a reading or writing operation that generated this error
Example:
Sub Driver1_OnCommError(Type, Size, Element, N1, N2, N3, N4)
  Application.GetObject("Data.InternalTag1").Value = _
    Application.GetObject("Data.InternalTag1").Value + 1
  Application.GetObject("Data.EvtType").Value = EvtType
  Application.GetObject("Data.Size").Value = Size
  Application.GetObject("Data.Element").Value = Element
  Application.GetObject("Data.N1").Value = N1
  Application.GetObject("Data.N2").Value = N2
  Application.GetObject("Data.N3").Value = N3
  Application.GetObject("Data.N4").Value = N4
