HorizontalPercentFill
Number Use this property to specify a percentage of an object's horizontal area to fill. Acceptable values for this property vary from 0 (zero) to 100. This property works along with the HorizontalFillStyle property, which informs how that fill is performed. Default value of this property is 100.
