HorizontalFillStyle
HorizontalFillStyle
Enum Defines an object's horizontal fill. This property works along with the HorizontalPercentFill property, which informs the percentage of an object must be filled. These two properties allow a simulation of a level fill in an object, such as a tank level.
Available options for the HorizontalFillStyle property
Option
Description
0 - FillLeftToRight
Fill percentage is from left to right (default)
1 - FillRightToLeft
Fill percentage is from right to left
2 - FillCenterToEdgesH
Fill percentage is from center to border
