Variables Tab
Variables Tab
This tab allows defining default values for user-defined variables. These variables may also have their values changed at run time by using the SetVariableValue method.
Variables tab
Variables tab
The columns of this tab are described on the next table.
Available options for the Variables tab
Option
Description
Name
The name of a user-defined variable
Value
A combo box where a value's data type can be defined. The available options are Empty, NULL, Boolean, Char, Byte, Integer, Word, Long, Dword, Currency, Single, Double, Date, Decimal, and String
