Alarms |
Possible causes
A CSV file with Alarms to import has an error in its columns of the indicated type. Alarm files must always have the minimum number of columns expected, according to every type. Extra columns are skipped. To know the correct way to create a CSV file for Alarms, please check topic Generating a CSV File Manually, on E3 Studio chapter.
Solution
There are three possible answers to that question in the error message:
•Yes: This process of importing Alarms inside this CSV file proceeds, ignoring only this error about the number of columns. The Alarm whose columns are incorrect is not imported
•Yes (All): This process of importing Alarms proceeds, ignoring all subsequent Alarms with error in the number of columns that may exist in that CSV file
•No: The process of importing stops, but Alarms already imported are preserved
To prevent this error, this CSV file must be created according to recommendations on chapter Alarms.
IMPORTANT |
Although Tag and Alarm files have the same extension (.csv), internally they are different. Hence, an Alarm file is not suited for Tags and vice versa. |
Check Region and Language configurations on Windows Control Panel, and if the decimal separator is the same used in this CSV file. TIP: create an Alarm in E3 and use the export tool, using the resulting file as a template for generating new Alarms.
Use the Others format, and type "MM/dd/yyyy HH:mm:ss.000". This configuration for an E3Browser is performed on Data Source tab, on Format column of each field. For an E3Alarm, such configuration is performed on Columns tab, by clicking Properties on each field.
The name of this Alarm Server is not specified in the E3Alarm, or it is not correct. For an E3Alarm to capture and display active Alarms, users must configure the name of an Alarm Server to access. To do so, change the value of Alarm Server column of the desired Connection on Connections tab of E3Alarm's properties window, or use the Properties List and select the AlarmServer property.
•To delete a Tag linked to an Alarm: Select this Tag with the mouse and press the DELETE key
•To delete an Alarm: Select this Alarm with the mouse and press the DELETE key
•To delete an Area: Select this Area and press the DELETE key
The SQL syntax for every database supported by E3 is the following:
•Access:
SELECT InTime, OutTime, Message, FormattedValue,
IIF(Severity = "0", "High",
IIF(Severity = "1", "Medium", "Low"))
AS Severity FROM Alarms;
•SQL Server:
Severity = CASE Severity
WHEN 0 THEN 'High' WHEN 1 THEN 'Medium'
WHEN 2 THEN 'Low' END FROM Alarms;
•Oracle:
DECODE(Severity, 0, 'High', 1, 'Medium', 2, 'Low')
