Licenses |
Elipse Software provides two playback packages, according to its tools:
•Basic Playback
•Advanced Playback: This is a Basic Playback plus Video Recording and Screen Capture tools
Each one of these packages is dimensioned according to the number of points (Tags and Alarm Sources) stored on a database. For example, a Basic Playback 1000 allows performing a playback on a database with up to 1,000 points. If a database contains more points than the available licenses, a database assembling process fails and an error message is then displayed, indicating that there are no available licenses to execute a playback.
An E3 Studio license includes an Advanced Playback license with no limit on points, although it is limited to the last six hours of data stored on a database. This allows an application developer to test playback without purchasing licenses for this.
In Demo mode (when there is no protection device), a playback also works in Advanced mode without a limitation on points, although limited to display only the last six hours of data stored on a database, relative to the current server time.
IMPORTANT |
If a protection device is a Master- (E3 Studio + Runtime) or Runtime only-type, playback is only available if there are licenses programmed on this protection device. For more information about limitations of E3's Demo mode, please check topic Limitations of Demonstration Mode. |
