System Events Recording |
Generated whenever there is a change in the options on the Events Recording tab of the Domain Configuration window
•%USER% contains the name of the user who changed the Events Recording tab
•%SESSION% contains "E3 Server" (menu on Windows Notification Area)
•%MACHINE% contains the name of the computer where the Events Recording tab was changed
•%CAUSE% contains a detailed message about this modification. Please check topic Event Causes for more information
