Domain Security |
Generated whenever there is a change in the options of the Security group on the Properties tab of the Domain Configuration window, where:
•%USER% contains the name of the user who changed the Security group on the Properties tab
•%SESSION% contains "E3 Server" (menu on Windows Notification Area)
•%MACHINE% contains the name of the computer where the Security group on the Properties tab was changed
•%CAUSE% contains a detailed message about this modification. Please check topic Event Causes for more information
