Connections Tab |
The Connections tab allows managing Alarm Filter connections with local or remote Alarm Servers.
Connections tab
Available options on the Connections tab
Option |
Description |
Add Connection |
Adds a new Connection to an Alarm Filter. This option corresponds to the Add method of the Collection of Connections |
Remove Connection |
Removes the selected Connection. This option corresponds to the Remove method of the Collection of Connections. NOTE: The Connection created automatically with an object cannot be removed |
Connection Name |
Name of this Connection. Press the F2 key to edit this name. This option corresponds to the ConnectionName property of a Connection object on the Collection of Connections |
Server Name |
Friendly name to identify a Domain from the selected Alarm Server. This option corresponds to the DomainName property of a Connection object on the Collection of Connections |
Alarm Server |
Name of an Alarm Server, which can be a local Domain or a Remote Domain. This option corresponds to the AlarmServer property of a Connection object on the Collection of Connections. Click to select an Alarm Server using AppBrowser |
Connection Filter |
Name of a Filter that contains the configuration of the alarm filter, defined on the Filters tab. This option corresponds to the FilterConnection property of a Connection object on the Collection of Connections |
