Filters Tab |
The Filters tab allows managing filters from an Alarm Filter.
Filters tab
Available options on the Filters tab
Option |
Description |
Filters |
Combo box with currently available Filters |
Configure |
Opens a configuration window for the selected Filter, described next |
Add |
Adds a new Filter to the Collection of Filters. This option corresponds to the Add method of the Collection of Filters |
Remove |
Removes the selected Filter. This option corresponds to the Remove method of the Collection of Filters. NOTE: The Filter created automatically with an object cannot be removed |
When clicking Configure, the window on the next figure is opened to configure the selected Filter.
Properties of the selected Filter
Available options on the properties window of a Filter
Option |
Description |
Name |
Name of this Filter. This option corresponds to the FilterName property of a Filter object from the Collection of Filters |
Filter by Alarm Area |
Determines a filter by Alarm Area. If users want to use a filter, specify it in this option or leave it blank. This option is equivalent to the AreaFilter property of a Filter object from the Collection of Filters |
Simple Area Filter |
If the Filter by Alarm Area option is not blank, this option is enabled and, if selected, filtering by Area is based only on matching the initial part of a name. Otherwise, it considers the entire name of an Area. This option is equivalent to the SimpleAreaFilter property of a Filter object from the Collection of Filters |
Use custom filter |
Allows informing a custom filter for alarms. This option corresponds to the CustomFilter property of a Filter object from the Collection of Filters |
Filter by type |
Enables the type of filter applied to an alarm. Available options are Only alarms, Only events, or Alarms and events. This option is equivalent to the FilterType property of a Filter object from the Collection of Filters |
Filter by severity |
Enables or disables viewing severity degrees. Available options are Critical, High, Medium, or Low. This option is equivalent to the ShowCriticalPriority (Critical), ShowHighPriority (High), ShowMediumPriority (Medium), and ShowLowPriority (Low) properties of a Filter object from the Collection of Filters |
