Command Screen |
1.Insert a new Screen in the project, named "CommandScreen", sized as 200 x 200 pixels.
NOTE |
To review the procedure to insert a Screen, please check chapter Screen and Screen Objects. |
2.On this CommandScreen, insert a PumpCommand-type object.
PumpCommand object
3.On the CommandScreen's OnPreShow event, create the next script.
Item("PumpCommand1").PumpSource = Arg
4.To create the script on the previous exercise, select, using AppBrowser, the XControl PumpCommand1 on CommandScreen and, on its right side, select the PumpSource property.
5.Type " = Arg".
