Screen and Screen Objects
Screens are windows for monitoring processes, where users insert objects that are part of the interface of operators with a system. Each application can have an unlimited number of Screens.
Screen Objects are graphical elements that can be inserted on Screens to create a visual interface with a process. These objects can be created using the toolbar of a Screen or using the Objects menu.
Once selected an object to create, keep the left mouse button pressed on a Screen area while moving the mouse pointer. A dotted rectangle shows this object's size and shape. When releasing the left mouse button, the object is then positioned inside the specified area.
