Table Configuration
Table Configuration
To access the configurations of the table used by a Storage, right-click this object in Organizer and select the Properties option to open the window on the next figure.
Storage tab
Storage tab
Each option on the Storage tab has a corresponding property. The available options on this tab are described on the next table.
Available options on the Storage tab
Option
Description
Database Server
Defines a Database server. This option is equivalent to Storage's DbServer property
Table name
Defines a table name. This option is equivalent to Storage's TableName property
Discard data from the main table
Enables or disables discarding data from the main table. Data is considered old according to the Discard data older than option. This option is equivalent to Storage's EnableDiscard property
Determines a time interval, in minutes, hours, days, or months, during which data is kept on the main table. If data is older than the interval on this option, it is discarded. This option is equivalent to Storage's DiscardInterval property and the option to select a time unit for this interval is equivalent to Storage's DiscardTimeUnit property
Perform discard every
Determines a discard interval, in minutes, hours, days, or months, for old data on a table. This option is equivalent to Storage's VerificationUnit property
Move discarded data to the backup table
Enables or disables storing discarded data on the secondary or backup table. This option is equivalent to Storage's EnableBackupTable property
Discard from backup data older than
Determines a maximum time interval, in minutes, hours, days, or months, for data on the backup table until it is discarded, regardless of the time data remains on the main table. For example, to keep data for 24 months on the main table and six more months on the backup table, this option's value must be 30 months. This interval must be longer than the one configured in the Discard data older than option of the main table. This option is equivalent to Storage's BackupDiscardInterval property and the option to select a time unit for this interval is equivalent to Storage's BackupDiscardTimeUnit property
Create Table
Generates this table structure on the Database. This option is also available by right-clicking a Storage object in Organizer and selecting the Create DB Structure option
After defining all table configurations, click Create Table. This action creates a table structure on the database.
The table structure of a Storage is similar to a Historic table, with a table of definitions, a main data table, and a backup table, if selected. For users to identify externally that it is a compressed table, check if the _Fields table was created.
_Fields table
_Fields table
This table contains the Fields described on the next table.
Fields on the _Fields table
Field
Description
FieldDeadBand
Dead band
FieldDeadBandUnit
Dead band unit, as a percentage of the previous value or as a percentage of engineering limits (a fixed value)
FieldDescription
Field's description
FieldEU
Engineering unit
FieldHighEng
Tag's higher limit
FieldID
Index of a Field registered on a Storage
FieldLowEng
Tag's lower limit
FieldMaxRecTime
When this time expires, data must be stored automatically
FieldMinRecTime
Minimum variation time to store data
FieldName
Field's name
FieldQuality
Field's quality
FieldScanTimeMs
Scan time that must be used to rebuild Tag's chart, in milliseconds
FieldSize
Field's size
FieldSource
Link used by this Field to obtain its values
FieldType
Field's data type
FieldVARTYPE
Field's native data type. Possible values are 0: Undefined, 3: Integer, 5: Double, 8: Text, or 11: Bit
Storage implementation allows users to not worry about how data is stored on tables. However, for a better understanding of how this module works, and to allow access to other programs, the format of a table is explained next.
Options for table management described in the previous item apply to three table sets generated by a Storage, according to the Table Name option.
This happens because, for every type of stored magnitude, a set of tables is automatically generated: a set for analog Tags, another one for texts, and one more set for digital Tags. This way, every Storage can manage up to seven tables, if users specify that three types of Tags must be stored:
<TableName>_Fields
<TableName>
<TableName>_Text
<TableName>_Bit
<TableName>_Backup
<TableName>_Text_Backup
<TableName>_Dig_Backup
The _Fields table contains a description of Fields to store, which usually stores the same information defined in Storage's Fields configuration, in addition to link an automatic index to each Field. All other tables have a fixed format:
E3TimeStamp: Field that stores date and time of a Tag variation. If the communication protocol supports sending time information, this Field contains a device's timestamp
Quality: Contains information about point's quality (Bad, Uncertain, or Good), according to its usage in Elipse E3 and according to OPC standards
Index: Creates a relationship between the stored Field and its respective name stored on the _Fields table
Value: Stored value. For an analog table it is a Double-type Field, or a real number. For a digital table it is an integer number, and for a text table is a variable-sized NVARCHAR Field, as specified in the StringFieldSize Field
