Alignment |
Allows users to align Screen objects among them or relative to a Screen. The available options for alignment are described on the table Available options on the toolbar of a Screen.
NOTES |
•The Horizontal Flip and Vertical Flip options have the following behavior: •For multiple selections, each one of the objects is individually flipped •The status of the buttons (pressed or not) changes according to the vertical or horizontal flipping of the objects, but only if the reflection status is the same for all selected objects •Buttons are disabled if the Screen is selected, or if there is no object selected •Screen objects can be adjusted to the nearest pixel, which is known as a Snap to Pixel effect, by using the shortcut key CTRL + Spacebar. |
