Toolbar
Toolbar
A Screen's Toolbar contains options that allow users to execute certain tasks quickly without using menus, such as adding a Command Button. The next table contains the available options on a Screen's toolbar.
Available options on the toolbar of a Screen
Option
Description
Select Select
Enables a selection mode
Pan Pan
Enables using the pan feature on a Screen. NOTE: At run time, this option is available only if a Screen's ScreenAlignment property is defined as paCenter
Area Zoom Area Zoom
Allows applying a zoom to a specific area of a Screen. To do so, left-click the initial point and drag the mouse to the final point. NOTE: At run time, this option is available using the shortcut key CTRL + SHIFT + Left mouse button, but only if a Screen's ScreenAlignment property is configured as paCenter
Fit Fit
Toggles between resizing the Screen to fit in the visible area and restoring the previous zoom level and scroll bar position (CTRL + 5 or CTRL + CLEAR)
Rotate Rotate
Enables a rotation mode
Tab Order Tab Order
Shows an identification for a browsing order among objects
Edit Connection Points Edit Connection Points
Allows editing connection points among objects. This option is only enabled in XControl objects
Bring to Front Bring to Front
Brings an object to the front inside a group (ALT + HOME)
Send to Back Send to Back
Sends an object to the back inside a group (ALT + END)
Bring Forward Bring Forward
Brings an object forward inside a group (ALT + PAGE UP)
Send Backward Send Backward
Sends an object backward inside a group (ALT + PAGE DOWN)
Zoom Zoom
Allows editing the level of zoom of a Screen
Layers Layers
Allows editing the layers of objects on a Screen
E3Alarm E3Alarm
Inserts an E3Alarm-type object
E3Browser E3Browser
Inserts an E3Browser-type object
E3Chart E3Chart
Inserts an E3Chart-type object
Playback Playback
Inserts an E3Playback-type object
Line Line
Inserts a Line-type object
Connector Connector
Inserts a Connector-type object
Rectangle Rectangle
Inserts a Rectangle-type object
Rounded Rectangle Rounded Rectangle
Inserts a Rounded Rectangle-type object
Ellipse Ellipse
Inserts an Ellipse-type object
Arc Arc
Inserts an Arc-type object
Freehand Freehand
Inserts a Freehand-type object
Polygon Polygon
Inserts a Polygon-type object
Curved Polygon Curved Polygon
Inserts a Curved Polygon-type object
Text Text
Inserts a Text-type object
Display Display
Inserts a Display-type object
SetPoint SetPoint
Inserts a SetPoint-type object
Picture Picture
Inserts a Picture-type object
Scale Scale
Inserts a Scale-type object
Group Group
Groups a selection of objects
Ungroup Ungroup
Ungroups a selection of objects
Linear Slider Linear Slider
Inserts a tool for linear sliding
Rotation Slider Rotation Slider
Inserts a tool for rotation sliding
Check Box Check Box
Inserts a Check Box-type object
Option Button Option Button
Inserts an Option Button-type object
Combo Box Combo Box
Inserts a Combo Box-type object
Command Button Command Button
Inserts a Command Button-type object
Label Label
Inserts a Label-type object
List Box List Box
Inserts a List Box-type object
Scroll Bar Scroll Bar
Inserts a Scroll Bar-type object
Spin Button Spin Button
Inserts a SpinButton-type object
Text Box Text Box
Inserts a TextBox-type object
Toggle Button Toggle Button
Inserts a Toggle Button-type object
Align Left Align Left
Aligns two or more objects to each other, using as reference the left coordinate of the last selected object
Align Right Align Right
Aligns two or more objects to each other, using as reference the right coordinate of the last selected object
Align Top Align Top
Aligns two or more objects to each other, using as reference the top coordinate of the last selected object
Align Bottom Align Bottom
Aligns two or more objects to each other, using as reference the bottom coordinate of the last selected object
Align Horizontal Center Align Horizontal Center
Aligns two or more objects horizontally by the center to each other, using as reference the last selected object
Align Vertical Center Align Vertical Center
Aligns two or more objects vertically by the center to each other, using as reference the last selected object
Same Width Same Width
Applies the width of the last selected object to all other selected objects
Same Height Same Height
Applies the height of the last selected object to all other selected objects
Same Size Same Size
Applies the width and height of the last selected object to all other selected objects
Center Horizontally Center Horizontally
Centers an object on a Screen, according to its horizontal coordinates
Center Vertically Center Vertically
Centers an object on a Screen, according to its vertical coordinates
Space Across Space Across
Applies the same horizontal distance to three or more objects to each other
Space Down Space Down
Applies the same vertical distance to three or more objects to each other
Flip Horizontally Flip Horizontally
Applies a horizontal reflection effect to the selected objects
Flip Vertically Flip Vertically
Applies a vertical reflection effect to the selected objects
Grid Grid
Shows or hides the grid
Edit Grid Edit Grid
Allows editing grid properties
Background Color Background Color
Allows selecting a background color for a Screen or for a Screen object from a list of pre-defined colors or create a new custom color
Foreground Color Foreground Color
Allows selecting a foreground color for a Screen or for a Screen object from a list of pre-defined colors or create a new custom color
Border Color Border Color
Allows selecting a border color for a Screen object from a list of pre-defined colors or create a new custom color
Border Style Border Style
Allows selecting the type of border displayed by a Screen object from a list of pre-defined styles. Possible values for this option are Normal, Dash, Dot, DashDot, DashDotDot, or No Border
Border Thickness Border Thickness
Allows selecting a thickness for the border line of a Screen object from a list of pre-defined thicknesses between 0 (zero) and 2.5 millimeters
Fill Style Fill Style
Allows selecting a fill type displayed by a Screen or by a Screen object, that is, how a match is performed between background and foreground colors of an object
Object Shadow Object Shadow
Applies a shadow to an object
Move Shadow Up Move Shadow Up
Moves an object's shadow up
Move Shadow Down Move Shadow Down
Moves an object's shadow down
Move Shadow Left Move Shadow Left
Moves an object's shadow to the left
Move Shadow Right Move Shadow Right
Moves an object's shadow to the right
Shadow Color Shadow Color
Selects an object's shadow color
Font
Determines a text's font
Font Size
Determines a size for a text's font
Font Color Font Color
Determines a color for a text's font
Bold Bold
Formats a text in bold
Italic Italic
Formats a text in italic
Underlined Underlined
Formats a text in underline
Aligns a text to the left margin
Align to Center Align to Center
Aligns a text to the center
Aligns a text to the right margin
Refresh Domain and Run Viewer from Current Screen Refresh Domain and Run Viewer from Current Screen
Refreshes the Domain, executes Elipse E3 Viewer, and displays the current Screen. This option is only available if a Domain is executing, that is, after using the Runs or Stops Domain Runs or Stops Domain option on the Default toolbar
