Configuring a Section Report
By using this option, users can configure specifications of a Section Report, such as page, printing, and styles. The next figure shows the Page Setup tab for a Section Report.
Page Setup tab
Page Setup tab
Available options for the Page Setup tab
Option
Description
Top margin
Specifies the margin for the top of a page
Bottom margin
Specifies the margin for the bottom of a page
Left margin
Specifies the left margin of a page
Right margin
Specifies the right margin of a page
Gutter
Specifies a page margin
Mirror margins
Enables or disables a mirrored margin of a page
The next figure shows the Printer Settings tab of a Section Report.
Available options for the Printer Settings tab
Option
Description
Paper Size
Specifies the size of a paper
Width
Specifies the width of a paper
Height
Specifies the height of a paper
Orientation
Specifies a paper orientation in a printer. The available options are Printer Default: Settings according to a default printer, Portrait: Vertical page layout, or Landscape: Horizontal page layout
Collate
Sorts the printing process
Duplex
Duplicates the printing process
Paper Source
Specifies settings and type of paper for the printing process
The next figure shows the Styles tab of a Section Report.
Styles tab
Styles tab
Available options for the Styles tab
Option
Description
New
Creates a new style
Delete
Deletes the selected style
Export styles to file
Exports all styles to a file with the .reportstyle extension
Import styles from file
Import the styles from a file saved using the Export styles to file option
Font name
Selects a font for the selected style
Font size
Selects a font size for the selected style
Bold
Applies a bold effect to the selected style
Italic
Applies an italic effect to the selected style
Underline
Applies an underline effect to the selected style
Strikethrough
Applies a strike-through effect to the selected style
BackColor
Selects a background color for the selected style
ForeColor
Selects a color for the text of the selected style
Horizontal Alignment
Selects a horizontal alignment for the text of the selected style. The available options are Left (default), Center, Right, or Justify
Vertical Alignment
Selects a vertical alignment for the text of the selected style. The available options are Top (default), Center, or Bottom
Script
Selects a type of font script for the selected style
NOTE
Importing a style file from a Section Report implies in overwriting all configured styles.
The Global Settings tab determines general settings for the drawing area.
Global Settings tab
Global Settings tab
Available options on the Global Settings tab
Option
Description
Snap Lines
Allows using snap lines or not to align controls
Snap to Grid
Indicates whether controls move from a snap line to another one when aligning or not
Show Grid
Shows or hides the grid
Grid Columns
Number of grid columns
Grid Rows
Number of grid rows
Grid Mode
Grid's view mode. The available options are Dots: Shows the grid as dots or Lines: Shows the grid as lines
Dimension lines
Determines whether dimensions must be shown or not when resizing an object
Show Delete Prompt
Select this option to show a warning message when deleting a parameter or calculated field
Ruler Units
Determines the type of unit of the ruler. The available options are Inches or Centimeters
Preview Pages
Determines the number of pages to show when selecting the Preview Preview option. The minimum value for this option is 1 (one) and the maximum value is 10,000. The default value of this option is 10
