Historic Field
Historic Field
A Historic Field Historic Field object represents a Field on the Historic's table on a database, according to the next figure.
Historic Fields
Historic Fields
The available options to configure a Historic Field are described on the next table.
Available options for Historic Fields
Option
Description
Name
Name of this Historic Field on the Historic's table. This option corresponds to the Name property of a Historic Field
Primary Key Primary Key
Indicates whether this Historic Field is used when defining a Primary Key on the Historic's table. This option corresponds to the PrimaryKey property of a Historic Field. Please check topic Primary Key Field for more information. Selecting this option automatically creates a PrimaryKey object and its respective Primary Key Field object. Clearing the selection of this option removes the Primary Key Field object but keeps the PrimaryKey object
Type
Data type of this Historic Field on the Historic's table. Possible values for this option are 0: fdText, 1: fdInteger, 2: fdDouble, or 3: fdDateTime. This option corresponds to the Type property of a Historic Field
Source
Data source of this Historic Field on the Historic's table. This option corresponds to the Link property of a Historic Field
Size
Size of this Historic Field on the Historic's table. This option corresponds to the Size property of a Historic Field
NOTE
The Field and Order options are not available for edition on Historic Fields. These options are only available for Index Field and Primary Key Field objects.
