Shortcuts |
This option allows executing applications installed with Elipse E3 via E3 Admin's contextual menu on Windows Notification Area. The following applications can be executed:
•Elipse Event Log Viewer
•Elipse E3 Studio
•E3 Tweak
•Elipse E3 Viewer
The Log Viewer item opens Elipse Event Log Viewer, already with the file corresponding to the active Elipse E3 log session. For more information about this application, please check Elipse Event Log User's Manual.
If there is a Domain already executing locally, the Elipse E3 Viewer item on this menu opens an Elipse E3 Viewer to the local Domain. Otherwise, or if the SHIFT key is pressed, opens Elipse E3 Viewer's initial screen, where users can select the server and other options, as described on topic Elipse E3 Viewer and WebViewer - Elipse E3 Viewer Execution - Via Start Menu.
