Via Windows Start Menu |
To execute a client application, users can access an Elipse E3 Viewer, available on Windows Start menu. Elipse E3 then shows the dialog box on the next figure, so that users can inform an application's server path.
Starting Elipse E3 Viewer window
If E3 Server is on the same computer as Elipse E3 Viewer, select the Local Server option. If they are on different computers, select the Network Server option and inform either a name or an IP address of the computer executing E3 Server. If E3 Server is available in a port other than the default (6515), inform this port number in the Network Server option right after the IP address, separated by a colon. To connect in Read-Only mode, select the Start Viewer in read-only mode option.
