Online Event |
N1 |
Address of a slave. Use the value 900 for a broadcast address |
N2 |
0 (zero) |
N3 |
102 |
N4 |
0 (zero) |
This Tag is related to the Automatic Scanning of Events and indicates if that Block Tag is in Online or Offline mode, allowing a diagnostics on the connection with a slave. That Block Tag goes to the Online mode whenever the communication with a device is successful, and it goes to the Offline mode after a certain number of communication errors. This value can be configured in the Tag goes offline after n comm. errors option. For more information, please check topic Automatic Scanning of Events. Possible values for the Value property are 0: The Automatic Scanning of Events Block Tag is in Offline mode or 1: The Automatic Scanning of Events Block Tag is in Online mode.
