Syntax of a JSON Template
To extract or assemble the content of a message, users must declare a template, which allows specifying the format of this message and which parts must be transformed into data. Each template must use keywords placed in the position of the values to extract. The available keywords are described on the next table.
Available keywords for templates
Keyword
Description
TS_TEXT(format)
Timestamp, in Text format, used as the timestamp for a Block Tag or I/O Tag. The meaning of each field is described on table Available options for the TS_TEXT keyword
TS_UNIX
Timestamp, in seconds since 1970, or UNIX format. This value can be a number or a text, and it is used as the timestamp for a Block Tag or I/O Tag, that is, 1504198675 or "1504198675"
QL_OPC
Quality, in OPC DA standard, using 1 (one) byte. This value is used directly as the quality value in a Block Tag or I/O Tag, without transformation. For more information, please check table OPC DA standard
QL_BOOL
Quality in Boolean standard. If the value is greater than 0 (zero) or the "true" or "TRUE" expression, quality is good. If the value is 0 (zero) or the "false" or "FALSE" expression, quality is bad
E3VAL
Specifies a value extracted in the sequence that it occurs for a Block Tag, each value in a Block Element. If there is only one E3VAL value in a message, the template can also be used with an I/O Tag. Values received as text may be converted to numbers, as described in section Conversion of Values Received as Text. This keyword inside an array declares a List-type field, according to section List-Type Fields
DUMMY
A variable field, but whose value must not be sent to I/O Tags
Repeat_E3VAL
A keyword that can only be used inside an array in JSON format to indicate that repeated elements inside that array must be processed independently by this Driver, returning a reading for each set. A template can have this keyword only once
Option
Description
%a
Abbreviated weekday, in English
%A
Full weekday, in English
%b
Abbreviated month, in English
%B
Full month, in English
%C
Century
%d
Day of the month, starting with 0 (zero)
%e
Day of the month, starting with a space
%f
Milliseconds, from 0 (zero) to 999
%h
Hour in 12-hour format
%H
Hour in 24-hour format
%m
Month
%M
Minute
%p
AM or PM
%S
Seconds
%y
Year with two digits
%Y
Year with four digits
%Z
Timezone, an international code that converts time to a GMT (Greenwich Mean Time) format
Offset of GMT time in the format ±HH:MM
The next code contains examples of timestamps formatted by the TS_TEXT keyword.
"2014-07-11T15:26:37Z" -> "TS_TEXT(%y-%m-%dT%H:%M:%SZ)"
"Mon Jul 10 11:04:47 BRT 2017" -> "TS_TEXT(%a %b %d %H:%M:%S %Z %Y)"
"2018-05-02T10:29:28.622-02:00" -> "TS_TEXT(%Y-%m-%dT%H:%M:%S.%f%+)"
OPC DA Standard
Bit
7
6
5
4
3
2
1
0
Description
Q
Q
S
S
S
S
L
L
Available options for the OPC DA standard
Option
Description
QQ
Two quality bits
SSSS
Four sub-status bits
LL
Two limit bits
QQ
Possible values are 0: BAD, 1: UNCERTAIN, or 3: GOOD
SSSS
Possible values are 0: BAD_NONSPECIFIC, 1: BAD_CONFIGERROR, 2: BAD_NOTCONNECTED, 3: BAD_DEVICEFAILURE, or 4: BAD_SENSORFAILURE
SSSS
Possible values are 0: UNCERT_NONSPECIFIC, 1: UNCERT_LASTUSABLEVALUE, or 4: UNCERT_SENSORNOTACCURATE
SSSS
Possible values are 0: GOOD_NONSPECIFIC, 1: GOOD_LOCALOVERRIDE, or 6: GOOD_NONSPECIFICLOCALTIMESTAMP
LL
Possible values are 0: FREE, 1: LOW, 2: HIGH, or 3: CONST
Examples of Configuring Templates in JSON Format
A file in JSON format containing an array with multiple data sets must include the Repeat_E3VAL keyword in the template right after the opening bracket of that array, according to the next example.
  "MessageType": "DUMMY",
  "TagData": [
    Repeat_E3VAL {
      "Temperature": "E3VAL",
      "Humidity": "E3VAL"
  "MessageDesc": "DUMMY"
In this case, when receiving a message with 2 (two) data sets, for example, the OnRead event of a Block Tag is triggered for each set, as shown in the next code.
Sub [Sensor-001_OnRead]()
  Application.Trace Item("Temperature").Value
  Application.Trace Item("Humidity").Value
If other E3VAL-type values are declared before or after a Repeat_E3VAL-type value, these are replicated for each set, with the Repeat_E3VAL-type value always as the last in the receiving Block Tag, according to the next example.
  "MessageType": "E3VAL",
  "TagData": [
    Repeat_E3VAL {
      "Humidity": "E3VAL"
  "MessageDesc": "E3VAL"
A Block Tag with the Block Elements Type, Description, Temperature, and Humidity can generate, for each OnRead event, values according to the next code.
"Test";"Description";11;12 => First OnRead event
"Test";"Description";14;66 => Second OnRead event
"Test";"Description";70;55 => Third OnRead event
A Case Without Reading Repetition Per Set
If users want to trigger an OnRead event for each set, a template can be declared without a Repeat_E3VAL-type value, using only one E3VAL-type keyword to capture the array, according to the next code.
  "TagData": "E3VAL",
In this case, the received array is expanded based on the number of elements, resulting in a single reading on the OnRead event, in the format of the next example.
array(11, 12); array(14, 66); array(70, 55) => Single OnRead event
If a template contains more than one E3VAL-type keyword, that is, non-DUMMY, the array is not expanded, according to the next example.
  "TagData": "E3VAL",
This reading is performed on a single OnRead event, in the format of the next example.
"Test"; array(array(11, 12), array(14, 66), array(70, 55)); "Description"=> Single OnRead event
NOTE
The body of a request is built in UTF-8 format, as the JSON format requires, and the response is also interpreted in UTF-8 format. Values with accented characters can be normally used on Block Elements.
List-Type Fields
A field of a request's body can be declared as a list, using the E3VAL keyword inside an array, according to the next example.
  "channels": ["E3VAL"],
  "id": "E3VAL"
This template contains two Block Elements, the first one corresponds to the channels field and the second one to the id field. A field declared as a list uses a single Block Element, and the value written to this Element defines the contents of this list, according to the next table.
Examples of filling in a List-type field
Value Written to a Block Element
Field Sent on a Request
"1/1"
"channels": ["1/1"]
array("1/1", "2/2")
"channels": ["1/1", "2/2"]
NOTE
Do not use more than one keyword inside the same array, such as in ["E3VAL", "E3VAL"], because all positions correspond to the same field and the last value written replaces the previous ones. To send a list of objects, use the Repeat_E3VAL keyword.
When the value extracted by an E3VAL keyword is received as text, that is, between quotes in JSON format, this Driver converts it to a number only if the whole text is a number, that is, only digits, optionally a leading minus sign, and at most one decimal separator, which can be either a period or a comma. Any other text, even one made only of digits, periods, or hyphens, such as an IP address or a date, is delivered to a Tag exactly as received. This rule also applies to values inside arrays and objects, and also to JSON Path Tags.
Examples of converting values received as text
Received Value
Value Delivered to a Tag
"123"
Number 123
"-1,5"
Number -1.5 (a comma is accepted as decimal separator)
"192.168"
Number 192.168
"007"
Number 7 (seven)
"192.168.17.30"
Text 192.168.17.30 (IP address with more than one separator)
"2025-12-22"
Text 2025-12-22 (date with a sign not at the beginning)
"10-20"
Text 10-20
