Configuring Properties Offline
The available parameters in the configuration of properties can also be accessed at run time if this Driver is started in Offline mode, by using String-type parameters described on the next table.
Parameters for offline configuration
Parameter
Data Type
Ping.PingTimeout
Unsigned integer
Ping.MaxNumberOfThreads
Unsigned integer
Ping.PingScan
Unsigned integer
Ping.WaitOnFirstRead
Boolean (zero or one)
Ping.DisableInactiveTags
Ping.MissedScans
Unsigned integer
Ping.DNSTimeout
Unsigned integer
Ping.UseAsyncDNS
Ping.SingleHostName
String with the name of a host
Ping.UseSingleHostName
Ping.UseCompatibleMode
Ping.NumberOfDataBytes
Unsigned integer
Ping.PingDefaultRetries
Unsigned integer
For more information about the offline configuration at run time, please check topic Documentation of I/O Interfaces.
