Importing Tags |
The Import Tags tab brings some features for Tag importing from a TIA Portal (Totally Integrated Automation Portal) automation project.
Import Tags tab
The Import Tags tab shows a tree view structure of Tags already imported and saved to this Driver's project. When users include a new Driver in a project, the initial state is an empty structure, only with a Tag Browser folder. Users can include imported Tags selecting the TIA Portal version and using the Open Importer option described on topic MProt TIA Portal Importer.
If there are Tags already imported to this tree view structure, users can use the Remove option to remove the selected Tag and the Remove All option to remove all imported Tags. Click OK to save all Tags and display them on Tag Browser.
NOTES |
•Only the LReal data type is not supported when importing Tags. If there are variables with this data type in a project, they are ignored by the importer, which proceeds with the import process of the variables with other data types. •Blocks with ArrayDB and InstanceDB data types are not supported when importing Tags. |
